mzamora
- Jan 28, 2013
- 5
Hello!
I've been dealing with the idea of using a car radiator for cooling an electric engine. The engine has the connectors made for hoses and it can be cooled with glycol/water (50/50).
But, I can't find any good piece of advice related to the heat transfer coefficient of any car radiator nor the head loss of the water that goes inside it. I know I can make a rough guess, but I'd prefer not.
The only experimental values I found:
- A 4025 Btu/min car radiator and its curves (of course that heat depends on the flow, at least) - This curve on slide 19 that looks like a good piece of info, but has no references
Do you know more about this topic? I saw that there are papers related to nanoparticles used to improve cooling properties, but also no detailed info. It's important to note too that the temperature ranges will probably differ.
For now, I'll make a wild guess and let fly some numbers.
