captures to drawing or power point
JeniaL
547
found on this forum useful macro to capture an image and then insert it into powerpoint but i have to run marco many times to capture all the annotations. is there any way to automatically export all the annotations/captures to powerpoint or catdrawing with capture name?
i have an .exe at work that do all the job but it outputs bad quality images especially with big parts.
thanks in advance.
Yeah, I know that macro, it was modified by me after Derek's solution, try to search for FTA in this forum, you can find something here about this problem, I remember that someone tried same thing but I don't remember if it was solved or not.
What I know is that FTA is not a "common" workbench (even if it should be).
Fernando
