Hi there,
I have been tasked with designing a pneumatic cylinder and was asked to do some calcs on what size bolts I should use to bolt the two endcaps of the cylinder to one another with the honed tube between them (Essentially I need to calculate if 4 off M10 capscrews will be good enough)
Unfortunately I never had the opportunity to complete any tertiary engineering qualification so my theoretical knowledge is abit limited. I am now in a situation where I feel like I am floundering abit and most of the guys at work are too busy to help or are not able to.
Please go easy on me with the explanations and a little patience please.![[blush] [blush] [blush]](/data/assets/smilies/blush.gif)
Some details are as follows:
The cylinder max force will be 9.2kN. There is no cushioning except for an o-ring in the face of the endcaps (The piston bumps into the oring which acts as an endstop bumper). We aim to run the cylinder fast (140 cycles per minute).
I have attached a rough model image to help convey the basic tie rod style design concept a little better.
