tristan_a6
- May 15, 2018
- 7
Hi everyone,
I was going through section F11 of the AISC code, let's say that the plate to be designed is actually cantilevering. The plate is attached to a column on one end, nothing on the other. Imagine some sort of flag pole where the flag would be a steel plate. Plate would be exposed to wind on weak axis and SW on strong axis. Plate will have a 40 ft2 area but be only 3/8" or so thick.
I want to check the plate for bending in weak axis for wind load and bending as well as LTB in strong axis. It seems like F11 section is only applicable for a member that would be supported on both ends. Is it the case?
Thanks for your help
