Anthony1780
- Aug 16, 2008
- 4
I hope someone can help me with the following problem.
I need to know what the minimum length and diameter of fixed support would be required on one end of a solid steel shaft of 320mm diameter with a 500mm overhang, to prevent any deflection from the horizontal. There would be zero load applied in this situation as it would be in a rest state. The shaft is currently 1000mm long and can be machined to achieve the required size.
I have tried some cantilever formulae but I can't get my head around them as it is outside my field of experience.
Any guidance would be most appreciated.
