Cantilever Beam - which model best represents?
hgordon
Chemical
Jan 23, 2018
33
Hi there,
I have a setup as shown in the following schematic: The 'cantilever beam' sits laterally onto another 'support beam' with two bolts holding it.
Originally I modelled it simply as the two bolts as pinned supports, but now I think the 'support beam' edge should be a third pinned support??
As this 'support beam' is also supporting downward force?
The model of two bolts is follows: The model of two bolts and 'support beam' is as follows:
Thoughts?
Thanks,
hello
The model with two reactions at each bolt is most accurate. Except the bolt further from the pivot will take the most load. In proportion to its distance from the pivot. As the stretching and tension in bolt will be more.
This assumes no bending of the beam to the right of the pivot, which is not fully true, but accurate enough.
There will always be a load at a pivot point or line
Neither model is correct. The edge of the support beam will be an upward reaction, and the bolt furthest from the edge of the support beam will be in tension.
DaveAtkins
