I have the following VBA code in a Module within Excel:
Sub Prueba_1(AttachToInstance)
'AttachToInstance = True: usa una instancia de SAP ya abierta (no abre un nuevo SAP)
'AttachToInstance = False: abre una nueva instancia de SAP
Dim ret As Long
'Path del ejecutable del SAP
Dim ProgramPath As String
ProgramPath = "C:\Program Files\Computers and Structures\SAP2000 18.1.1\SAP2000.exe"
'Path del fichero SDB
Dim ModelPath As String
ModelPath = Hoja1.txt_Fichero.Text
'Crear instancia SAP
Dim mySapObject As cOAPI
Set mySapObject = Nothing
If AttachToInstance = True Then
'Abrir modelo en una instancia de SAP ya abierta
'Obtener el objeto de SAP activo
Set mySapObject = GetObject(, "CSI.SAP2000.API.SapObject")
Else
'Crear una nueva instancia de SAP
'Crear objeto OAPI helper
Dim myHelper As cHelper
Set myHelper = New Helper
'Obtener el objeto SAP
Set mySapObject = myHelper.CreateObject(ProgramPath)
'Iniciar aplicación
mySapObject.ApplicationStart
End If
'Obtener una referencia a cSapModel para acceder a todas las clases y funciones de OAPI
Dim mySapModel As cSapModel
Set mySapModel = mySapObject.SapModel
'Inicializar modelo
ret = mySapModel.InitializeNewModel
'Abrir modelo de SAP definido en el cuadro de texto
ret = mySapModel.File.OpenFile(ModelPath)
End Sub
If I try to work in an already open instance of SAP (with AttachToInstance=True) it works like a charm.
However if I try to open a new instance (AttachToInstance=False) I get an error "ActiveX component can't create object" when running "Set myHelper = New Helper".
I can't see where the problem is, as long as the "CSI_OAPI_Documentation_v18.hlp" says it has to be done that way, including some examples.
Of course I have included the reference to SAP2000v18.TLB in Excel, in case anybody has this doubt.
Any help would be really appreciated.
Thanks.
Dim ret As Long
Else
'Iniciar aplicación
End If
'Inicializar modelo
End Sub
Thanks.
