CAN'T SEE RESULTS IN PRO-MECHANICA STRUCTURE
  • Thread starter Thread starter wkyeo
  • Start date Start date
W
wkyeo
Guest
Dear All,
After running a simple pro-mechanica structure analysis with no error diagnosed, I could not produce the result page because it gave me this message
A file access error has occured. Cannot open e:/pro-engineer/study1/analysis1.rwd
When I check the directory for a .rwd file, there was none.
Pls help
Thanks In Advance
I've been here before. It's confusing, but the solution is simple.
Only select the folder for the analysis once to highlight it. Don't double-click it where it adds it to your path. It should not appear in your path. So in your case, if you're in the e:/pro-engineer directory, just left-click study1 to highlight it, then click Accept.
I don't have Pro/E in front of me right now, so I'm going by memory. I'll double check on this tomorrow.
