Can't Find File or Object Library
deanOtw
Computer
TW
Hi guys,
I have written a Macro, and it run's fine on my PC, and some other PCs. However, Most of PCs will show a message such as "Can't Find File or Object Library". I know the file is there at where it should be. what is likely the problem is? anyone knows?
Thanks!
check that You have installed VBA to Your PCs.
If You have not installed CATIA directcly from CD
you should install VBA as separate step, See the manual
for details.
Regards TPale
