We are working with a crushed rock from a mine site as a subgrade and the requirement is 98% compaction. The proctor values show 8% optimum moisture and density of 2350 kg/cum. We sat in one area for three minutes with a 1000lb diesel tamper and the density went from 89 to 89.5, a long way from the required 98%. The other tests were at 91. Even a measurement of the subgrade surface with the nuclear densometer showed compaction of 92 and yet you could not make an indent in the surface even by jamming your heel into it.
The crushed mine waste has coarse angular material and very fine powder material but almost nothing in the mid range. The temperatures in Northern Canada are below zero at night and not much higher in the day so we are concerned about watering and then packing.
Is 98% really required or should we be using another parameter to judge the adequacy of the subgrade. Like I said, we packed the same area for 3 minutes and did not move the plate tamper at all and still we could not appreciably increase the density.
We are trying to get a thickened concrete slab installed for the erection of a pre-engineered metal bldg.
I am happy to contact anyone who has information that could help us.
