Cannot create the export dir/files
chwi23eng
Computer
EU
thread561-303730
Hi
We have the same problem as the thread 561-303730 with error message "Cannot create the export dir/files" when we open a NX part from TC 8.3. We have recently uppgraded from TC 2007 to TC 8.
Our NX version is 6.0.5.3.
Did you get any answer? What was the solution?
/Christer
Can you specify where the temp folders are located on your system, you can check this by RM click on my computer, properties, Advanced tab, on the bottom you will find system variables.
In User variables for .... (your user name) there should be a variable TEMP with value %USERPROFILE%\AppData\Local\Temp something like this and TMP with value %USERPROFILE%\AppData\Local\Temp
If there is no entry here it should be one in the System variables. If it points to an other directory verify your security settings (see if you have right/read permissions for this folder).
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
My TEMP and TMP value is set to %USERPROFILE%\Local Settings\Temp and I have write access to that directory.
Best Regards
Christer
in the options menu from TC is the Check-out directory (under general) pointed to any of these directories?
Best regards,
Michaël.
24.0 GB
I notice this in the thread 561-303730 and we have Check-Out directory set to c:\\temp
Best Regards
Christer
Michael do you know if Ed English manage to solve the problem in thread567-303730 ? Our sympton is the same as his.
Best Regards and thank's for you help
Christer
Or you made a typo or the directory is wrong? It should stated c:\temp not c:\\temp
Best regards,
Michaël.
24.0 GB
Also the settings you refer to are in File - utilities - customer defaults --> Gateway - general - directories (see attachement)
Best regards,
Michaël.
24.0 GB
 http://files.engineering.com/getfile.aspx?folder=8ffe65bb-f938-4cd0-b81f-d4a0f600ca04&file=Capture.JPG
