Can you move? 1
SDO
CA
Does anyone know if there is a way to move components of a subassembly (relative to the other parts of the subassembly) while the subassembly is inserted in an assembly? Or, the only way to do it is go back to the subassembly, move the component, then return to the full assembly?
Thank you,
Sorin
Right click the assembly in the feature tree, go to properties, and check "flexible"
Thanks Miller7778, good tip.
Sorin
