Can we run servomotor in animation
  • Thread starter Thread starter ksrikanth325
  • Start date Start date
K
ksrikanth325
Guest
Hi All,
Hope everyone is doing well...
I have a doubt regarding animation.. in my office there is no license for mechanism module.. so is there any possibility to run servomotor in animation.
waiting for ur reply,..
Srikanth
To run a servo motor, you do need a license of MDX (Mechanism Design Extension). This comes with almost all basic licenses. If you don't have MDX, contact your sales representative, as he or she should be able to convert/upgrade your licenses to the latest base package (most likely at no cost).
To run servometer in animation you can used some method.
1.To add a servo motor click on the Servo Motors icon on the
Insert tab.
2. A definition window will open up and Select the motion axis that you want to animate.
3. The Profile tab in the definition window can be used to specify
the desired motion profile. A constant velocity profile is arguably
the simplest motion profile for an animation.
4. You can graph the position, velocity, and acceleration profiles for
your components by selecting the appropriate check boxes and
clicking the Graph icon in the lower part of the dialog box.
Thanks and Regards
CETPA Infotech
Embedded system Training In Lucknow
if you want to run servometer than you need to have licence of MDX .
