can views be copied across multiple drawings?
  • Thread starter Thread starter biflic
  • Start date Start date
B
biflic
Guest
I would like to copy detailed views across multiple sheets and or multiple drawing files.
I have a standard spot face weld detail that I use and I usually include the detailed view on several sheets in a drawing set. I would like to be able to insert the view fully detailed into a drawing sheet and not have to worry about cleaning dimensions or naming the veiw, kind of like a wblock in autocad. Can this be done? If so how?
What about saving the view as a drawing, then using Advanced > Merge to insert it into other drawings?
Ed
I'll give that a try. If it works I'll be very happy.
Thanks!!!
Can't seem to find the merge command you spoke of. Mind giving a pointer? Pro/E 2001
Thanks.
Never mind. Wasn't thinking. All is working now.
The ability to edit would be nice.
