When the rebar was bend first time. The inside corner area went under compression and become hardened, and hence less ductile. Now when you straighten it up, you impose compression on outside face of corner, which now became hardened and less ductile. So you created two zones with less ductility and hence less tensile capacity. Alternatively, rebar can be heated to avoid this but cost factor!! ! May be new rebar will be cheaper.
