Can I have standard material for steel
  • Thread starter Thread starter venu2citd
  • Start date Start date
V
venu2citd
Guest
Can I have standard material properties for steel in inches,which I can assign directly to my part
Thank you
Venu
Here below PTC parameters for standard steel:
ND_RelParSet_K01 = {Name = STEELPARAMETERS ={ Name = PTC_MATERIAL_TYPE Type = Integer Default = 9 Access = Full},{ Name = PTC_FAILURE_CRITERION_TYPE Type = String Default = 'NONE' Access = Full},{ Name = PTC_FATIGUE_TYPE Type = String Default = 'NONE' Access = Full},{ Name = PTC_YOUNG_MODULUS Type = Real Default = 2.900000e+07 psi Access = Full},{ Name = PTC_POISSON_RATIO Type = Real Default = 2.700000e-01 Access = Full},{ Name = PTC_THERMAL_EXPANSION_COEF Type = Real Default = 6.500000e-06 / F Access = Full},{ Name = PTC_SPECIFIC_HEAT Type = Real Default = 4.076000e+05 in^2 / (sec^2 F) Access = Full},{ Name = PTC_THERMAL_CONDUCTIVITY Type = Real Default = 5.372000e+00 lbf / (sec F) Access = Full},{ Name = PTC_MASS_DENSITY Type = Real Default = 7.324000e-04 lbf sec^2/in^4 Access = Full},{ Name = PTC_BEND_TABLE Type = Real Default = 0.000000e+00 Access = Full},{ Name = PTC_XHATCH_FILE Type = String Default = '' Access = Full},{ Name = TEMPERATURE Type = Real Default = 0.000000e+00 F Access = Full}}
Bye
Which type of steel are you referring to? There are many many different types of steel that all have different properties. Examples would be, there is CRS (Cold rolled steel), HRS (Hot rolled steel), Stainless steel and so on. Under each of those headers there are many selections from that. For example, Under steel that would be considered cold rolled, there is Steel 1010 or Steel 1018 (1018 is a very common crs used, good properties, good weldability, can be formed well). If you know the type of steel you are wanting to use, then I suggest you goto this website: Matweb They have a great database of material properties that you can use in creating the materials for your models.
