Can anyone recommend DN 15 fittings for cooling water pipe to BS EN
pch1
Petroleum
Nov 6, 2002
58
Can anyone recommend DN 15 (1/2") fittings to be used on a cooling water piping, in a waste water treatment plant.
The client's spec reads "Mild/carbon steel pipes, fittings and joints shall conform to the relevant provisions of BS EN 10216-1:2002; BS EN 10217-1:2002 & BS EN 10224:2002"
Unfortunately in BS EN 10224 the smallest size is O.D. 26.9mm, which is similar in size to 3/4" pipe at O.D. 26.7mm (As per ASME B36.10).
Managed to come up with BS 3799 class 3000 SW fittings.
