mechanic36
Automotive
- Apr 6, 2001
- 5
Hi all! Same question as in automotive that I wrote a couple of days back, now modified with more detail.
Can an engine oil leak from a rocker cover gasket onto an exhaust manifold (NOT the cat) be the sole cause of an under bonnet fire? Flash point of oil is around 200 deg centigrade, temp of exhaust manifold is what at normal operating temp? (checked one the other day and found it to be 55 deg C - NOT up to full op temp though)
Thanks for any help.
