Can a job rerun after recovery of ABAQUS crash
Cansand
102
I have in some cases huge jobs that requires almost 40 hours to be completed, but sometime the program crashes while the job is still runing, . In this case I had to do EndTask to ABAQUS and reopen it with the job recovery.
I can see that the Job is still runing. I went to the job Monitor but the job is not moving. How can I get the job rerun
The job is probably ok, even though /CAE has shut down. The process running the job (standard.exe or explicit.exe) is completely separate from /CAE, so even though you have lost the interactive monitoring, as long as standard.exe is still cranking away you are fine.
Is there a message file (.msg) you can look at? or a status file (.sta). You can look at these to see what is going on...
