Can a feature of size without any geometric tolerance have an IB or OB?
Tarator
Automotive
CA
Hi all,
I am wondering, from simply a definition point of view, whether a feature of size without any geometric tolerance applied to it can have an IB (inner boundary) or OB (outer boundary), based on ASME Y14.5-2009?
Thank you.
Certainly. That IB or OB would simply be the max or min size as allowed by the given size tolerance. (This assumes that it's a rigid part, not a commercial stock size, etc.)
To clarify -- I should have said the MMC, which is of course the max or min size, as appropriate.
This chart might help. The asterisk is just a reference to Rule #1.
Belanger,
Thank you. I thought so, too. But I was not sure.
