Can’t Render
  • Thread starter Thread starter saspinall
  • Start date Start date
S
saspinall
Guest
I'm playing about trying to use Wildfire 2 inbuilt photorender but can't seem to get it to work right. Ive setup the room etc and when I go to Model Display for a quick real-time render everything is ok but when I try the Render icon under render control it says that the render is sucessful but all i get is a small 1" square image of the room around my part. It's not the full room just a bit of it. Any ideas anyone ??
Stu
Try this:
go to Render Setup and find the tap : OUTPUT
check the 'Render To' option, what does that say?
I set it to Full Window.
That will render it completely, other options are available there to...
Ries
thanks for the reply
It is set to Full Window already
Stu
