Israr...
I cannot create cyl CS in part mode, even if I use the methode you shown above... The offset type = cylindrical doesn't mean the CS created is cylinderical type. So, what's the real? can we create a true cyl CS in part mode? Here's what PTC said about CS:
<H1>About Coordinate Systems</H1>
Coordinate systems are reference features that can be added to parts and assemblies to do the following:
<UL>
<LI ="kadov-p-CTopic-Text-Bulleted">
Calculate mass properties.
Assemble components.
Place constraints for Finite Element Analysis (FEA).
Provide manufacturing operation reference for tool paths.
Use as a reference for locating other features (coordinate systems, datum points, planes, imported geometry, and so on).
For most common modeling tasks you can use coordinate systems as direction reference.</LI>[/list]
<H4>Cartesian, Cylindrical, and Spherical Coordinate Systems</H4>
Pro/ENGINEER always displays coordinate systems with an X-, Y-, and Z-axis. When referencing a coordinate system to make other features (for example, a datum point array), the system can interpret the coordinate system in three ways:
<UL>
Cartesian
