abusementpark
- Dec 23, 2007
- 1,087
I noticed that the Steel Joist Institute requires all steel joists to have a certain amount of camber depending on the top chord length. Do ever specify any deviations from this requirement?
I checked my company's standard specifications and found that they do not allow cambering of joists. However, I am not sure if this has always been enforced. I can see a situation where cambering could cause issues with the deck installation if you have two adjacent joists with significantly different span lengths.
What is your standard practice? Do you allow the cambering? Are there ever installation problems if you do?
