Cam mechanism - eccentric cam and followe
  • Thread starter Thread starter bryanbryan010
  • Start date Start date
B
bryanbryan010
Guest
I need some tutorials on the mechanism setup for an eccentric cam and a shaft follower.
I'm using wildfire 2 but have problems with the depth display settings.
I only used cylinder connect constrain for the follower and the eccentric cam. Both of them are 90 degrees apart.
Any advise is appreciated. Thanks in advance.
There's a demo on this in the Pro/E Wildfire 2 installation:
<PROEWF2_loadpoint>\demos\demo\mdx\tutorial3\cam_fol lower.asm
bryanbryan010,
If you upload your parts or send the assembly to me ,I will make the mechanism for you.
Israr
Edited by: Israr
