J
JDBlanck
Guest
The orange piece is free to rotate in the dark green base.
The blue cylinder is free to rotate along its axis.
The gray piece is permanently fixed to the blue cylnder
The light green cylinder is permanently fixed to the green base.
My goal it to raise the orange piece so that the blue cylinder is perpendicular to the green base, thus causing the gray piece to strike the light green cylinder which in turn will cause the blue cylinder to rotate.
I have tried (and failed) to create the desired movement by creating a cam connection between the light green and grey pieces with liftoff enabled.
Any sugestions would be appreciated.
