Hi All,
I looking for suitable material for cam. It is the first time I am working with cam. what is the common cam material nowadays? My application is high load, low speed, metal to metal, both sliding and rolling contact, grease lubrication. The material needs to have good wear and corrosion resistant (for phamaceutical industry). I'm looking at stainless steel 304 because of its excellent corrosion resistance but it cannot be hardened (wear resistance is proportional to hardness). I think i need to achieve at least rockwell 60C. anything can be done on SS 304 to achieve 60C hardness?
if i use 400 series stainless steel, any processes can be used to enhance its corrosion resistance property?
i am a little bit confuse with all the secondary processes for stainless steel (or steel), eg. chrome plate, nitriding, nitrocarburizing, electroless nickel, case-hardening, cold working, PVD coatings, CVD coatings, ...
please help.
Any suggestions? any other material suggestion is welcomed!
thank you!
ngee
please help.
thank you!
ngee
