P
puppet
Guest
anyone have any idea why i can not create a cam connection between the
bearing surface of the vertical slider to the rotary cam?
it doesnt let me select the raised cam edges.
the cam was made using
just a vss-cut using a datam graph
any help would be appreciated.
the slider is connected via
1) cylinder constraint. ( up and down)
2) planar constrait. ( aviod twist)
hm,m might replaces them with a slider constraint.
