Callout Text aspect ratio
griffisj
4
I am using V19. I have callout text in my titleblock and it is pulling info from file properties. I need to have the text maintain its height, but I need to change the width, basically make it narrow to fit inside the box. Is there a way to do this? I've been looking and trying and can't find anything.
Thanks!
you can't change that because it's how the font is designed. For
instance Verdana is wider than Arial. You have to choose a
different font which is narrower at a given height (i.e often
described as condensed). Any TrueType font can be used.
dy
