I see this all the time with DIN (German) drawings.
The 6.3 is showing the default surface finish, and you shouldn't find it anywhere else on the drawing.
The 3.2 is showing that there is a different surface finish specified somewhere on the drawing for a specific area or surface.
As an example, you might see this on a drawing of a round part. You would have a surface finish of 6.3um on the entire part...EXCEPT where there is the same symbol from inside the parentheses is shown pointing to the bore.
The text behind everything (broken edges, plated), from what I have seen, looks like the literal translation from German. (no, I can't find the german version right now, mainly because I REEEEALY need it) It means "break all edges, and do it BEFORE plating"
Just for reference, I have seen up to 4 surface finish symbols on a drawing, one outside and three inside the parentheses. It's always a LOT of fun finding them all
"A Designer knows that he has achieved Perfection not when there is nothing left to add, but when there is nothing left to take away" - Antoine de Saint-Exupry
