Aug 2, 2005 #1 jdonville Geotechnical Joined Sep 29, 2003 Messages 985 Location US Is there an ASTM standard for verifying the readings from an indicator gauge? Jeff Jeffrey T. Donville, PE TTL Associates, Inc. http://www.ttlassoc.com
Aug 2, 2005 #2 MechEng13 Mechanical Joined Apr 24, 2003 Messages 198 Location US If there is one, I believe it would be ANSI with traceability to an NIST Standard. Alan M. Etzkorn Project Develpment Engineer Wabash National Corp. http://www.wabashnational.com Upvote 0 Downvote
Aug 2, 2005 #3 EdStainless Materials Joined May 20, 2004 Messages 16,349 Location Waukesha WI USA Indicator of what? This is an issue of calibration and traceability. For some devices there are standards for calibration methods. For most you are allowed to write your own, as long as you can prove that it works. = = = = = = = = = = = = = = = = = = = = Corrosion, every where, all the time. Manage it or it will manage you. http://www.trent-tube.com/contact/Tech_Assist.cfm Upvote 0 Downvote
Aug 2, 2005 Thread starter #4 jdonville Geotechnical Joined Sep 29, 2003 Messages 985 Location US EdStainless, The indicator gauges I am talking about are dial or digital deflection indicators with required accuracy of both 0.0001 and 0.001 inch. I should also throw in dial calipers. We need to be accurate to 0.001 inch for other ASTM methods. Jeff Jeffrey T. Donville, PE TTL Associates, Inc. http://www.ttlassoc.com Upvote 0 Downvote
Aug 2, 2005 #5 dbaird Electrical Joined Mar 31, 2000 Messages 412 I believe US standard accuracy grades and tolerances for pressure gauges are set forth by ASME B40.100-1998: Pressure Gauges and Gauge Attachments American Society of Mechanical Engineers 10-Dec-1998 ISBN: 0791825701 David Baird mrbaird@hotmail.com Sr Controls Designer EET degree. Journeyman Electrician. Upvote 0 Downvote
