Hi there,
I am doing some calculations on compression of co2 and therefore I need the isentropic volume exponent (kappa_p,v) and the isentropic temperature exponent (kappa_T,p) for a real gas.
These are defined as following (in "Thermodynamic Correlations, k-Exponents, Speed of Sound, and COP Data for Binary Refrigerant Mixtures" by Stegou-Sagia and Damanakis, University of Athens, Int. J. Thermodynamisc, Vol. 7 (No. 1), pp. 15-22, March 2004):
kappa_p,v = -v/p * c_p/c_v * (dp/dv)_T
kappa_T,p = 1 / (1-(p/c_p)*(dv/dT)_p)
(dp/dv)_T is the partial derivative of pressure with respect to specific volume at constant temperature.
My problem is that the everything I found about this subjects uses a Peng Robinson or a Redlich and Kwong EOS which is basically a classical van der Waals equation. Therefore it gives an analytical expression for the specific volume and can be differentiated so that you get an expression for the partial derivatives above.
But I cannot use the PR or RKS EOS for CO2 because of the accuracy so I'm using the LKP EOS which only gives an expression for Z that includes the compressibility factor of two fluids at a reduced state (the solution is calculated numerically as the expression for the reduced specific volume is not solveable analytically). This means no equation to differentiate.
Maybe I'm not seeing the wood for the trees but I have no idea how to calculate the isentropic exponents as I have no idea how to differentiate the EOS at a given state.
Any help is truly appreciated!
Greetings,
Daniel
PS: Please excuse any mistakes for English is not my native language.
Greetings,
Daniel
