We intend to install steam tracing on a pump for the purposes of maintaining a certain temperature, which enables the fluid in the pump to remain in liquid form.
What are the considerations for doing the heat transfer calculations for the required steam tracing?
My view is as follows:
- Volume of the fluid sitting in the pump when not in operation. This can be estimated from the pump drawings
- Surface area on which the tracing is being lined. Assuming this is on one face of the pump impeller casing area, the area can be estimated as the circular cross section (on the pump side) and tubular area (on the steam tracing side)
- Heat transfer coefficients for the pump material and for the steam tracing material (eg: copper)
- Ignore fouling or deposits inside the pump and inside the copper tubes
What else?
---engineering your life---
What else?
