Hi all,
Problem:
A packed column completely filled with liquid, a gas sparger is below the packed bed of the column. The gas flow rate through the sparger is 1000 (kg/hr) and the density is 1.56 kg/m3 (641 m3/hr). The liquid flow rate through bed and column is 120410 kg/hr and density is 1100 kg/m3. Calculate the buoyancy (upward) force exerted on the bottom of the packed bed (support grid bottom) by the sparged gas?
Answer:
Fa = V x density x g.
Buoyancy force = Volume of gas x density of liquid x acceleration due to gravity
Basis: 1 hour operation (steady state condition)
Fa = 641 x 1100 x 9.81 = 6917 kN.
I am not sure of the answer, and would like suggestions or possible answers how to solve this problem.
Questions:
1. I want to calculate the upward force exerted by the gas on the bottom of the packing?
Any help is appreciated.
Problem:
Answer:
Questions:
