elbulldogio
- Feb 26, 2010
- 7
Dear all,
I have been given a problem that involves a 3m length of pipe filled with water, that has a single support(support B on attached diagram) 2.5 m from the left leaving a span of 0.5m from support B to the right side of the pipe. The pipe is to be conneted to the other pipes in the line using slip on sleeves with integral gaskets.
I need to calculate how much shear occurs at the pipe ends that the slip on sleeves need to resist. So I have assumed the following:-
1. The sleeves act as simple supports to each end of the pipe.
2. Pipe stresses have been assumed as acceptable
3. Environmental and seismic effects are neglected.
Thus the problem now becomes a continuous beam with 2 unequal spans that is subjected to a udl of 397.65N/m (weight of pipe + weight of water).
The theory I have used is on the attachment, but the figures I achieve seem incorrect. I cannot see how the reaction at support B is larger than the total weight of the pipe.
I have been looking at this so long now that no matter how hard I try I cannot see the problem.
Could somebody please look at my theory and help me locate the error. Also please inform me if I have used the right theory in the firstplace.
Sorry sounds stupid, but I am not a piping engineer!!!
Many thanks in advance.
