aldumoul
- May 24, 2011
- 65
The customer's print calls out 250 ft-lbs of torque mininum on a weld. This part is cylindrical via a progressive die. And this part is welded to complete the cylinder. A round bar (1 foot long, close enough) is inserted into the inside diameter of the part.... on the other end of the bar there is a 0.75" air cylinder pushing up on the bar. The cylinder radius block attached to it (to easily make the conversion) The part is constrained in a fixture. There was a gage made sometime ago... In which someone calculated 50 PSI=250 ft-lbs. I Disagree. I calculated appx 565 PSI. Obviously there are other factors such as the friction created by seals, rings, etc in the cylinder. Let's consider them negligable.
Torque=P(A)Dist
Cylinder area @0.75"=Appx 0.442..... pi*(.375^2)
So 250 ft-lbs=P(0.442)*1 ft
Divide both sides by 1 ft (ft cancels out)
Next, divide both sides (0.442)...=565 PSI
Torque=P(A)Dist
