KimWonGun
- Oct 11, 2010
- 78
I am using an on-line calculator to estimate the pressure drop of a light motor oil across an orifice given two different operating scenarios:
The first assumes 200F oil temperature with the corresponding oil viscosity, Reynolds number, and flow coefficient.
The second assumes -40F oil temperature with the corresponding oil viscosity, Reynolds number, and flow coefficient.
Question 1: If I wish to observe the impact of temperature on the pressure drop across the orifice, is it correct to hold the flow rate constant?
Question 2: And if the flow rate is held constant, does it make sense that the pressure drop at -40F across the orifice would be much less than at 200F due to the higher fluid viscosity?
Question 3: If my objective is to determine what the transducer type (differential pressure or point) and range should be, is there a more effective way to estimate those values?
