BoomerSooner7
Industrial
Hello all,
We recently installed a high volume (3000 GPM, water) closed flow loop to test multi-staged centrifugal pumps which includes a booster pump being fed by a tank. We are using a Labview program to plot the measured performance curve against the catalog curve for the multi-staged pump being tested, everything is kosher there. However with this booster pump I want to add fuctionality to the program by calculating and displaying the NPSHa at the booster pump on the program. My inputs to the DAQ card are a suction pressure transmitter (30inHg - 30psig), an RTD and a flowmeter. My question is this; I need a formula based on any or all of these inputs plus the calculated vapor pressure of the fluid at the specified temp. via the RTD to display the NPSHa in feet. Note: the pressure transmitter at the suction impeller is in psig. Any thoughts?
