My company has various shaft/hub press fits of varying diameters where the shaft is knurled.
Shaft has a bore through it, steel, in some cases induction hardened.
Hub is a powdered metal.
In some cases the hubs occasionally crack, and in some other cases, the shaft bore closes down and needs to be honed to size.
I've been trying to find some way of showing the relationshipo of the knurled press fit dimensions to torque to try and optimize the designs and see if we can avoid the two above conditions. I'm familiar with the press fit design but I get stuck when knurling comes into the picture.
If anyone can point me to some theory behind how a knurl will effect a press fit so I can create a excel forumala sheet I would greatly appreciate it.
