The formauls are dependent on what the object is that your turning (Ballscrew, Belt & Pulley, Cylinder, Hollow Cylinder). Each have different equations.
For a solid cylder, parallel witht he shaft, the equations are as follow:
mD^2 Wr^2
J = ---- = ----
8 2g
or antoher
(pi)Lpr^4
J = ----------
2g
J = inertia (oz-in-sec^2)
m = mass (oz/m)
D = Diameter (in)
W = Weight (of cylinder) (oz)
r = radius (in)
g = gravity (386 in/sec^2)
pi = 3.141592564
L = length (in.)
p = material density (oz/in^3)
Now if the shaft was perpendicular to the motor shaft, then the formauls change:
WL^2
J = -------
48g(pi)
(use same legend as above)
Now if you switch to a belt and pulley, again, the formulas change:
Wr^2
Jpulley = -----
2g
J = Inertia (lb-in-sec^2)
W = weight of pulley (lbs)
r = pulley radius (in.)
To calculate the Inertia of the load:
Wr^2
Jload = -------
g
W = weight of load (lbs)
It looks like your sizing for servo or stepper based on your 10:1 comment. If your mismatch is higer than 10:1, you will need to add a gearbox. The Inertia seen to the motor is reduced by the square of the ratio.
Jload
Jreflected = ---------
GBratio^2
There are many software packages out there that can help what you want to do. Also, most motion control Mfgs will have an eng. reference in their catalogs with the formuals.
Give us the details (include your motion profile - how far in what time) and I will help you size it.
Cameron Anderson - Sales & Applications Engineer
Aerotech, Inc. -
"Dedicated to the Science of Motion"
