doug223
- Sep 7, 2010
- 9
Hi Everyone
I am trying to calculate if (at all) sea water will freeze inside a pressurised 12" carbon steel pipeline at 5 bar. The water will be non moving so I assume mass flow rate will be 0?
The wind speed will be taken to be 12.5 m/s. Air temp has been -15 C last night.
I have been following this guide attached. I have found in my search that the specific heat of sea water (generally) is 3985 J kg K.
I have found info for fresh water but not finding it as straightforward for a saltwater application.
Any help is greatly appreciated.
