Calculating hoop stress in threaded fasteners
debun
34
Does anyone know of a way to calculate the hoop stress generated by torquing fasteners? I am working on a design where OD of my fastener is critical and I would like to make it as small as possible but I don’t have a good feel for what the hoop stresses will be like.
agree, debun...no hoop stress in a bolt. Shank thickness is a function of the interaction between shear and tension, usually designed for one or the other and then a unity check on the interaction is done.
Torque on a bolt produces tension in the shaft and shear on the threads.
There is also shear stress in the shank due to the torsion applied while tightening the bolt.
hi loafer09
The shear stresses that Ron and I are refering to are those due to torsion during tightening,
desertfox
so is loafer09, if you read his post properly, he wasn't referring to single or double shear but torsion in the shank.
However this will never be limiting unless it is a custom bolt designed to fail before the threads.
There is a hoop stress unless it is a square thread. Otherwise the the normal force of thread on thread has both vertical and horizontal components, during and after torquing.
Michael.
Timing has a lot to do with the outcome of a rain dance.
Yes this is a regular angled thread. There is a hoop stress.
I believe the hoop stress would be:
(F*tan(thread angle/2))/(l*(D-d))
where F = fastener load, l = length of internal threaded nut, D = outside diameter of the nut or distance across flats, d = thread pitch diameter.
l*(D-d) is the hoop stress area.
F*tan(thread angle/2) is the radial force at the pitch diameter.
Derived from the geometry of the thread to determine radial force component on the thread causing the nut to dilate.
Ted
hydtools, that is probably a high estimate because it ignores friction.
Michael.
True, that would be worst case, fully lubricated threads and nut face. Accounting for friction will reduce the radial force. For a thread form angle of 60deg, thread friction and nut face friction both equal to 0.15, the reduced radial force would be L*(.5774 - .15 - .15) = L*.2744. Without friction the radial force would be L*.5774.
Ted
