Smokey2007
Did I do this right?? all places where i put "**" are the places i did calculations or made assumptions. the rest i found online.
here are my specs for a heat exchanger:
surface area: 2.4sq ft
capacity: 240k Btu/hr
flow capacity: 24 gpm
shell pipe ID: 1"
tube pipe ID: 3/4"
overall size: 4.5"*10 7/8"
** the shell's thickness is not given, so i will assume 1/4"
** and that the pipe's thickness is 1/8"
steam pressure 50PSI which equates to a temp of 281 F or 411.48K
density: 927.64 kg/m^3
specific heat: 4284.82 J/kg K
dynamic viscosity: .7168 kg/m hr
**calculate for velocity of steam
**v=4*flow rate/(pi*pipe's diameter^2)
**v=4*24GPM/(3.14*1"^2)
**v=10578 m/hr
**calculate hydraulic diameter of tube
**D=(r{outside}-r{inside})/2
**D=2(.875/2"-.75/2")=.125"=.003175m
therefore reynalds # = Dvp/u
**Re = .003175m*10578(m/hr)*927.64(kg/m^3)/.7168(kg/m hr)
**Re = 43463.9
now once i have this value and calculate the Prandtl number, I can determine the Nusselt number. i know these all deal with "convective heat transfer." but how does use this knowledge in determining the overall heat transfer properties of my overall system?????
i am aware of the following forumla and which each mean
dQ=kA(delta T)/dx
i am trying to solve for the "delta T" for both outside the shell, and inside the tube.
i realize i still need to calculate the resistances for 1. outside air against shell(convective) 2. shell's material(conductive), 3. steam against shell's material(convective) 4. steam against tube's material(convective) 5. tube's material(conductive), and 6. inside fluid against tube(convective).
what i just solved references #4(steam against tube's material).
shell pipe ID: 1"
tube pipe ID: 3/4"
**v=10578 m/hr
**Re = 43463.9
dQ=kA(delta T)/dx
