I'm designing a cylinder-shaped sealing component to a part that needs to have a face seal on the distal end of the part and a seal on the OD as well. I've attached a sketch of what I'm thinking for the component.
The part will need to be a single durometer material (to be chosen after the calculations of force required are made). So far, I'm thinking of a durometer material of 50-70 Shore D. The far right of the part will be the part used for the face seal and the curved geometry at the same side will be used as a radial seal.
I'm looking to determine how thick the material needs to be on the area on the far right the looks like an "S" but I'm not sure how I would go about doing this.
Thanks!
Nick
Thanks!
Nick
