Hello Everyone,
I have come across this rather interesting site in my quest to answer a question which is outside of my normal field. I hope that I can add to the community where I can, but also learn from the wealth of expertise that exists here.
So Normally I am working with materials. Today I would like to solve a problem on heat transfer. At least I think it is heat transfer.
Here is my situation.
I have a corrugated cardboard box with some material inside (solid form block of polymer) the polymer is temperature sensitive. It is in contact with the bottom surface of the box but not the sides or the top.
I would like to transport the box (and contents) by truck. The problem is that it can get very hot in the summer in the back of the truck and I need to keep the box cool.
What I would like to do is: create a mpdel which based on the temperature of the day (assuming the truck is in sunlight) how hot it will get inside the truck and how much heat will get to my substance inside the box and how long it will take.
Eventually I would like to also calculate how much cooling/heat energy I need to take away from the box to keep the contents within a certain temperature range for a given time.
I thought maybe the next steps should be applied:
1, Calculate temp inside the truck
2, Calculate the transfer through the box to the polymer
3, Calculate heat energy to remove to keep the polymer at a certain temp
It has been some time since I carried out anything to do with heat transfer. I would very much appreciate maybe some coaching here from the experts so I can relearn a little some of the theory as well.
Robert
Robert
