I'm calculating some valves heat loss.
Until now, i have been using a calculation method that uses a conversion from the valve diameter to equivalent pipe length, and then calculate normally as if it is a pipe.
Now i'm trying to validate this conversion factors, or to make some more accurate calculations?
Can anyone share with me how can i make this calculations??
Thanks!
Thanks!
