nowis
Bioengineer
- Jul 29, 2011
- 3
Hi all,
I'm trying to calculate the heat losses as well as the thermal time constant of a system with a forced water flow inside a horizontal plastic pipe. This is in order to determine what temperature and flow i should input to have a certain desired water temperature downstream of the pipe. I tried to solve the problem taking into account the forced convection inside the pipe, the natural convection outside the pipe, the conduction through the pipe wall and the axial conduction. The flow is laminar all along the pipe. I cannot solve this problem as I have to many unknowns (temperature inside and outside the pipe, upstream and downstream) due to the nonlinear external natural convection (it is not a constant wall nor a constant heat flux condition).
Is there a simple way to determine the temperature downstream of the pipe? Likewise, is there a way to quickly determine if the thermal time constant is mainly due to the axial conduction orto the convection?
Thank you for your help!
