Calculate pressure generated by fixed volume water in closed container
asimpson
300
sorry but I was never any good at thermodynamics but I need to show prove to some one that a fixed ammount of water in closed container can build up to explosive pressures if heated from 20 C to over 500 C.
Could anybody point me in the correct direction to calculate pressure generated.
Many thanks
rb1957 said:
PV = nRT
I was under the impression that a vapour was something that does approximate gas laws closely enough for that calculation.
JHG
" PV = nRT
I was under the impression that a vapour was something that does approximate gas laws closely enough for that calculation"
Only over a short temperature range. R varies over temperature and pressure, making this law limited in application.
i thought R was a function of temp and pressure (rather than a universal constant), but i'd expect you can iterate to a solution pretty quickly (that it is a well controlled function, with low derivatives).
R is a constant- what you are thinking of is that real gases are modelled by equations of state with all sorts of corrections.
