CAE: how to create a 3D spline or helix ???
neoflight
Aerospace
Feb 19, 2007
9
I am using abaqus cae to create a helix (inside) touching a shell cylinder. I need to independently create the sections for the helix. to make it clear; cae revolves the rectangular section in an angle (specifying the pitch) and the cross section (perpendicular to any line on helix) dimensions of the revolved section are not the ones I provided.
So i am now trying to specify the path using spline and then sweep the section thru it. But i cannot find a way to create a spline in 3D space. how can i do this?
anyother way to create a helix with a specified dimension? I mean iam concerned about any given section perpendicular to the helix path to be precise. Thank you in advance..
the following is an example of how to create a helical wire feature...
(watch the indents, they may get mangled in this forum)
from abaqus import *
from abaqusConstants import *
Mdb()
rad = 5.0
zFactor = 0.25
p = mdb.models['Model-1'].Part(name='Part-1', dimensionality=THREE_D,
type=DEFORMABLE_BODY)
xyz=[]
for i in range(100):
x = rad*cos(i/5.0)
y = rad*sin(i/5.0)
z = i*zFactor
xyz.append( (x,y,z) )
for j in range( len(xyz) ):
dtm = p.DatumPointByCoordinate(coords=xyz[j])
d = p.datums
p.WireSpline(points=d.values(), mergeWire=OFF, meshable=ON,
smoothClosedSpline=ON)
session.viewports['Viewport: 1'].setValues(displayedObject=p)
Thank you. that gave me the spline. excellent. But its not letting me use this as a path for my sweep.. i am relatively new to abaqus....
any help would be highly appreciated !
thanks again for the help
Use a CAD program for modeling and then import the part into CAE.
Can you try the following and let me know if the "revolve with pitch" command gives you what you want?
width = 20.0
height = 5.0
origin = (15.0, 0.0)
pitch = 50.0
numTurns = 2.0
s = mdb.models['Model-1'].ConstrainedSketch(name='rect', sheetSize=200.0)
g = s.geometry
s.setPrimaryObject(option=STANDALONE)
cl = s.ConstructionLine(point1=(0.0, -100.0), point2=(0.0, 100.0))
s.FixedConstraint(entity=g[2])
s.FixedConstraint(entity=g[cl.id])
s.rectangle(point1=(origin[0], origin[1]), point2=(origin[0]+width, origin[1]+height))
p = mdb.models['Model-1'].parts['Part-1']
p.BaseSolidRevolve(sketch=s, angle=numTurns*360.0, flipRevolveDirection=OFF,
pitch=pitch, flipPitchDirection=OFF, moveSketchNormalToPath=OFF)
#In above command try changing the following member: moveSketchNormalToPath=ON
s.unsetPrimaryObject()
