CABLE Connecttion
shakildor
35
Hi everybody,
Can anyone tell me how to model the joint of a cable stayed bridge at the top of the supporting tower where cable rests on a rolling saddle at the top of the tower.
This joint should transfer only (not horizontal load and bending moment)the vertical load from cable to tower
SHAKILDOR
why not model by assigning frame/cable releases not to carry horizontal load or moments at the connection with the tower?
Hi Masonmenos,
Thanks for response,....can you please be more specific in your suggestion...simply making the frame connecting the tower top as cable still transfer horizontal component of cable to tower which creates a great moment at the base of the tower....so please advice
shakildor, I'm not sure if I'm misunderstanding you or not. You can do both a) draw your cable and assign it tension only if you wish and b) assign Frame moment releases and/or shear releases in any direction at either end of your cable
If you assign frame releases such that the frame joint is 'free' in the horizontal direction(s), then there should be no resulting moment at the base from horizontal movement of the tower.
Does this answer your question? If not, please clarify further and explain why assignment of releases does not solve this problem for you
Hi Masomenos,
Thanks ......it solved my problem.I relesed moment at both ends in frames representating cables and i released moments and shear in one end only of the frame representating tower
Shakil
