Cable connectors : can I grind them?
Morquea
37
Hi
I have a number of feedthrough connectors TCF125-128AL for mono DLO 535 cable. The diameter of one end is too small. It's cause of varying OD diameter of the cable manufacturers. Southwire would have fit but not Carol.
My men proposed to grind the opening end for 3/32 inch width.
I was wondering what are the consequence of altering the connectors this way. Is the width of the aluminium important?
Danny Garant, ing.jr
Groupe Stavibel Inc.
If you alter a component, I'm pretty sure it loses its CSA listing. Is that acceptable to you or the AHJ?
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Why not use the proper connector?
Try TCF150-140AL
Bill
"Why not the best?"
Jimmy Carter
